OSPFv3.ProtoMgr.HoldOrigLTMinOrigIntv
Description
PM has been activated with a hold LSA origination interval smaller than its minimum LSA origination interval. OSPF will use the configured minimum LSA origination interval (if non-zero), but not the hold or maximum LSA origination intervals.
Remedy
To use full LSA throttling, ensure that the configuration of the minimum, hold and maximum LSA origination intervals are consistent.
Severity
Info
Message Text
%p1% The hold LSA origination interval %p2% ms is smaller than the minimum LSA origination interval %p3% ms.
Message Parameters
Name Type
p1 String
p2 sInt32
p3 sInt32
